Is anyone else having trouble with the Get Rooms by Level node? It was working for me previously and now I am getting nothing but null results. I have tried both versions 0.7.5 and 0.8.0, still no luck…
Where does the IndicesOf node come from?
Was this resolved - I’m having the same issue in version .8
This is in 0.8.1 and it appears to be working as it should.
Just downloaded 0.8.2 and i still get no rooms showing up - more thoughts?
You could select all rooms. Use element.levelnameasstring from rhythm and use a filter by bool mask as well.
Hi All, I have the same issue, but only when working with Revit2016. The same Dynamo graph (8.1) works with Revit 2014.
I think it’s something with the level parameter of the room, may be a API change that breaks the node functionality.
Did you try the filter I mentioned?
Hello Miguel Salvador,
Is it possible for you to share your files? (dyn and rvt) otherwise I will create new sets to test it on my side.
Have you tried in Revit 2015?
Revit 2016 is RAC or its a a simple Revit?
Thanks for the info.
-Ritesh
