Hello, I have a task of trying to make walls in the Dynamo script See through while the outer lines are visible. While also giving the studs in the Script a Bright color. Does anybody have any ideas?
Can you show what you have tried?
Manually setting graphic override to 60% transparent in view template can also work.
