"Search returned no results" when installing Packages
A post was split to a new topic: Package manager won’t connect
The same thing happens with Civil3D 2020.
What should I do ?
  1. Update to the latest version of C3D and Dynamo for C3D.
  2. Be patient for the list to appear. It can take a few minutes to populate.
  3. Try using https://dynamopackages.com/ and install via the web.
Updated C3D and Dynamo for C3D.
I downloaded the package from the link above and saved it in the root folder, but it wasn’t added to the library.
What does it mean to install via the web?
Make sure that when you unzipped the file you use 7zip or manually unblock all the DLLs in the package.
After unzipping it with 7zip, I was able to add the package to the library.
Thank you!
Hi! I have the same issue with Revit 2018 student version…search for dynamo packages gives n results…I have tried installing the updates but couldn’t find Collaboration for Revit security fix while I have installed all other mentioned in the link given above…secondly I am not sure if I need to install Revit 2018.3.3 or Revit 2018.0.3 security fix with a student license
Yes you will need to get Revit current. Install the 2018.3.3 update.
Hi, I was chatting with the Live agent and they gave me these two links for Revit 2019. Latest:
Hotfix:
https://up1.autodesk.com/2019/RVT/9CA05B9A-1913-0510-A1B4-FFF7A680FE55/Revit_2019_2_6.exe
Revit Personal Accelerator Security Fix for Windows 10 (.Net 4.7):
https://up1.autodesk.com/2019/RVT/9E4778E7-C6A9-4432-9EF4-E9F849FFF064/PACR.msi
Thanks and respects to all who posted, I installed these and now the package manager is working.
