I have a dynamo script that works in Dynamo but not from Dynamo Player. Any help?
can you reupload your screenshot with the node names visible?
I assume the issue is a dropdown node that doesnt have the correct input
What error does dynamo player put out?
There are no errors when I run the script. The issue is when I run the dynamo player it runs but doesn’t full export the data I want it to, however if I run the script through dynamo it does. Please see the updated image I forgot to show that I have the scripts linked up to the data export to excel node. The green in what I have made the input the pink is just the rest of the nodes to filter the data I want to export to excel.
I have some string and number nodes that I haven’t made an input for the dynamo player would this be the issue? should they be code blocks?
