I am running a script through Dynamo player, all I am doing in the graph is exporting the data to excel sheet through Write Excel Node as shown below
So the issue I am facing is the script runs smoothly when I run it through Dynamo core 2. However, when I run it through dynamo player I got message that the run completed but the excel files never get updated-- so the script is just not running fully through dynamo player. Any ideas on how to overcome this issue?
Yes, I tried to use anopther node with no luck. If I run the script from the graph everything works smoothly, only when I try to run it through the player–that’s when the script never run.
Many thanks, I literally followed the steps in the post you mentioned and manged to remove dynamo core 1.3.3 from windows but nothing changed–same problem
