Error running script in dynamo player
Tried to run my script but I get this error ?
Suggest a solution ?
Thanks in advance.
are you using a daily build of Dynamo, or did this graph come from a daily build of dynamo?
please post your file, my guess is that it is in JSON.
@Bzz fyi
Hi @Arun_Prakash Looks that there is a crash when reading the file. Might be an older version of the script. Can you open the file in recent Dynamo that comes with the Player ? If yes, try to save it and then run it again using player.
I get that error when I don’t first start dynamo to pick which version I want to use. I have both 1.3 & 2.1 on my machine and if I just start the Dynamo Player and try to run a script it just sits there till I click in the Revit model then I get an error like above.
