Hello guys, I’m a beginner in dynamo and I’m creating a script that consists of creating walls through the surface of the floor. But I would like the wall created to be on the inside of the floor, this being on the outside. Outside the floor. I wonder if anyone can give me a solution. Thanks
Try the Wall.Flip node from Clockwork package.
Thanks for your help. But where do I specifically put the knot?
Connect it to the output of Wall.ByCurveAndHeight node.
Okay and where do I put the information I want the wall to be created on the inside? In the location line, finishing face: internal
Where will the Nold Select model element be linked in the script? In the case of creating walls
You could use the Wall ByCurveAndLevel node in Genius Loci package which already has a wall location and a wall flip inputs.
Show, where do I specify what I want on the internal finishing face? In wall location?
Yes.
Show the previews under the node and show a screenshot of your floor in Revit.
Does your floor have a slope ?
I created a floor and select it to create the walls. But it still isn’t working
