Readers,
i have just started working with dynamo and i’m running into the problem that although all my units seem to be in meters a 2,4 units in dynamo is a 0,732 m in revit.
is there a setting ore checkbox i’m missing?
Kind regards
Readers,
Kind regards
stupid question maybe, but what about the units in revit and in your family?
That’ll be a conversion issue. Can you post your file here?
Conversion issue indeed. 3.28 is the ratio between feet and meter. Drop a Length From Number node in fornt of each input of the XYZ node and you should be fine. It is my understanding that the XYZ node will always treat a number input as metric feet, so you need to make your input a length. Veel geluk!
@andereas
worked like a charme.
Have to admit is a strange line of thought…
