I’m looking at interrogating projects dims but I’m struggling to understand what the Dimension.Value node is actually reporting.
I have a test project with 1 dimension in it which is exactly 7600.00mm long. When i stick it into the Dimension.Value node it retruns the following;
Units in the project are set to mm although changing ;this makes no difference to the value the node spits out…
I’m I just being thick here as to what it’s actually reporting?
Cheers
K.
