Hi!
I want to import a geometry (SAT file) to Dynamo so i can subtract it to a major solid. To do that I need to convert the .SAT geometry to a solid. Is it possible?
Thanks!!
Hi!
Thanks!!
Hi Marques,
If you are going from Rhino, I suggest downloading a package called Rhynamo
Alternatively, I haven’t tried it myself, but there is a node called “Geometry.ImportFromSAT” found in Dynamo.
Hello Marques,
Look at the image below for Importing SAT file to Dynamo and use those Soilds/Surface for further manipulation.
If you want to Import that ST file directly to Revit then use “ImportInstance.BySATFile”
Thanks,
Ritesh
