I have an interesting problem…
I was finicking with a custom node to log usage in graphs.
When i ran my graph in Revit 2022, my Revit 2021 session crashed. I didnt think much of it, until it happened in Revit 2023 aswell. this made Revit 2022 crash…
I have added the log below:
journal.0055.txt (3.4 MB)
Do you have an idea what is happening here @JacobSmall
Looks like an issue with the node itself, not really a problem with Dynamo. How are you recording the log?
This log was just the standard log you get when Revit crashes.
I think the problem occured when i tried to run the graph with the node, which contained python 2.7, which wasnt installed…
Still not sure how it manages to crash a revit version its not even running the dynamo graph in…
Sorry - should have been more specific.
How are you logging use with your node? My guess is there is a conflicting process being force closed which is causing the WPF collapse in the other Dynamo and Revit.
Oh hehe
I have copied Gavin’s tutorial node for node (almost)
What’s in the Python nodes?
Slightly cleaner method here in an updated video vs my older one, see how it goes:
For some reason, after i added this node, my graph gets rather unstable… (it’s a very large graph to be fair…)
Oh i can’t believe i missed that video!
Thank you, i’ll give this a go, love your videos!
I’ve also packaged the code up in a custom node in Crumple, dubbed as the ‘logger’.
If adding this was the route cause, it might be the issue. I can see how it may be causing some issues with concurrent RevitDynamoModel instances.
A few things to try:
- Gavin’s logger from Crumple. If that fixes stuff we can cleanly ID the route cause.
- Look into this Python for pulling the graph name, which utilizes a different means of accessing the file name: dynamoPython/dynamoAPICurrentWorkspaceInfo.py at master · Amoursol/dynamoPython · GitHub
