Run part of dynamo script in specified order
Hello! I have this dynamo script but i need the parts to run in sequence from top to bottom. I am not sure that dynamo does this by default?
The scrupt works for now but i would like clarity and help on how to make sure that the top group is run before the middle and bottom group :slight_smile:
Here is the image of my dynamo script
Thanks for any help :slight_smile:
Hello ,You could try play around with some passtrough
Hello Sovitek and thanks for you answer! :slight_smile:
Is this passthrough a package of some sorts?
Thanks for clarifying! Working with Graphs! Got it :smiley:
I will try with the clockwork passthrough node and see if that helps! :slight_smile:
Hi Lasse…clockwork have one or just in a codeblock…maybe timerdelay from Crumble could help as well…good luck :wink:
Works fine for me in some situation in our SCRIPTS :wink: :wink:
Im getting bullied just cos im a programmer :sob: :joy: :joy:
I used the Clockworks package and it does exactly what i want :slight_smile: Thanks you all!
No worries we know what you mean :wink: some people call it script other graphs ( probably the right term) but so long we understand each other its all good in my opinion,we have bigger issues with Dynamo :wink:
