Dynamo running logic
This is a question about the running background of Dynamo.
In what order do nodes run in a Dynamo script?
Let’s say I have a script which generates a certain type of elements in the project to certain points.
I also want to be sure the script doesn’t make duplicated elements, so there are 2 branches in the script: one ends in deleting these certain types of elements from the project, the other one creates new ones.
How can I be sure which branch runs first, so the newly created elements don’t get deleted?
Can this kind of logic in a script cause Dynamo to crash? Sometimes if I run a complex script, it tends to crash, and I don’t know what causes it.
The former function is just meant to be an example, not the actual problem.
I just like to see the logic of the running of a visual defined program.
Thank you for the answers!
Regards,
Gabor
If you want to make sure certain operations run in sequence I would recommend you try Clockwork’s Passthrough node. It’s really simple, but I made it specifically for that purpose. In some cases you might need to throw in a Transaction.End node, too, e.g. if you first delete some elements in a category and subsequently want to collect all elements of that category.
I tried using the standard Thread.Pause node, are they similar ?
Instead of setting up some manor of ‘pause’, it’s jusually best to use a ‘wait for’ to ensure one portion of the graph finishes executing before the next portion begins. That said, this thread is 7 years old so likely best to start a new topic outlining what you are trying to do and what you’ve attempted so far.
