Route Conduit by Circuit Path in Revit
no I change just the python node
a better way, if the goal is to take the circuits of each selected element
import sys
import System
clr.AddReference('RevitAPI')
#from Autodesk.Revit.DB import *
if isinstance(IN[0],list):
	lst_element = UnwrapElement(IN[0])
	lst_element = [UnwrapElement(IN[0])]
lst_pts = []
for elem in lst_element:
	lst_system = elem.MEPModel.GetElectricalSystems()
	for sys_ in lst_system:
		circuitPath = sys_.GetCircuitPath()
		lst_pts.append([x.ToPoint() for x in circuitPath])
OUT = lst_pts
Where is the second part of the script i.e. the script of the custom node “creating Lines from circuit path load name”?
i want that those circuit paths could get modified and follow the cable tray near to the mechanical equipment and the electrical equipment that feeds the circuit. Is it possible?
