Hi everyone!
I can’t rotate points with the “transform rotate” node.
Here are two screenshots to show you the problem.
- I apply the transform xyz node to the centers of ellipses, I see the axis on the floor moving but nothing happen to the points and then to the ellipses.
- I put directly the transform rotate node as center of ellipses, the ellipses rotate but stay on the xy plane.
Where is my mistake?
thanks you!
