Hi everyone,
I need to rotate and create a line over its center point by 5 degrees until it rotates 360 degrees. However, when using the geometry rotate, I can’t create more than one line each time I apply the node. Any solutions?
If it helps, I want to rotate the curve to acquire the restricted segments seen in the second print screen.
Thx in advance for the trouble.
Luís Sanhudo
