Rotate Element (archilab) doesnt work
Hello everyone!
Rotate Element from archilab seems not working in Revit 2020, Dynamo 2.1.0. But it worked well in Revit 2018.
I searched and found another node for this, it seems working, but it rotates around some far away axis, not the one that I chose.
But I decided to make topic about node from archilab, because its popular and well known and also it seems to be working to lots of people.
Here is an example. Element is Red, axis is green.
I also tried to provide XVector or YVector nodes to the axis, but nothing happened.
The result is always null, and no warnings or errors are returned.
And here is the code inside the node (just in case).
Please tell me what I am doing wrong? :sweat:
Use the Element Set Rotation of geniusLoci package.
I dont see the axis input in this. I need to be able to rotate element in different directions.
You want ?
which Pacakage use for Element.rotate.
DynaMEP
I download DynaMEP pacakge version 1.2.5. but that node not available.
Try reinstall it
Thank you for this, I tried it, but no matter what axis I put in “Exit” it always rotates around Z axis. So that doesnt help me.
I also unchecked “Always vertical” box in family. Tried other solutions from the forum based on python script. Also tried these nodes.
I editted one of them to be able to put in line (not vector).
(At least they are rotating around some far away axis. But not the axis i pick (as line). And still code is fine. I just cant get it. It seems like the problem is in Revit.
Encountered the same problem with ABT elements.rotate node.
I was trying to rotate an entire assembly of object around a hinge axis.
The catch is whatever vector you choose, the point of rotation will be at Origin with vector for direction.
You can do a workaround by getting the element.getlocation and moving it to Origin first. Then elements.rotate and then move it back to original location and align to the center of rotation. You can match the earlier location by the fact that the radial distance from the element location to the center of rotation will be constant.
Good morning.
I was trying the rotation node but it seems it only works with pipe joints, any recommendations for rotating my structural columna?
