Rotate revit family archi-lab.net
Hi
Rotate Family node from archi-lab.net doesn’t work in new Dynamo? Or I do something wrong? I remember that this node works fine in older Dynamo version, now I have “null”.
Hi @3dpipinggrabowski and welcome, think the axis input need a vector, try feed in the z vector
I I try Z and Y vector, the same result “null”. I think axis should be line
Hi @3dpipinggrabowski ooohh yeah think last time i tried that one i couldnt get it to work…could it work with ootb familyinstance set rotation or genius loci element set.rotation
In Genius Loci nod “Element set location” I can only rotaty on Z axis, ootb?
Yes true both will rotate about z, so another axis in these cage i use elementrotate from OpenMep package
thanks OpenMep node rotation works perfect
one thing regarding OpenMep, this package is not working on Revit 2024 :frowning:
allright it should…
That update 4 days ago Is working on Revit 2024 :slight_smile: Previous one was not working, Thanks
Great :wink:
