Rooms.DoorsOrWindows explanation
Would someone mind explaining how the Rooms.DoorsOrWindows node works? What types of inputs are required?
1_RoomDoorsOrWindows
This node will retrieve all doors (or windows) for a given room. Here’s how:
DoorsByRoom
Is there a way to find windows associated with an area instead of a room? I’m trying generate a list that correlates windows with areas on an Area Plan rather than rooms placed on a Floor Plan (I know, not ideal)…
Andreas, I copied the workflow you posted above and am only getting null results. Any idea why this might be happening?
1_Room.DoorsOrWindows not working
Notice how I left the Room input of Room.DoorsOrWindows unconnected? You should do that, too.
I will improve this node in the future so it can process lists of rooms without using a List.Map node (https://github.com/CAAD-RWTH/ClockworkForDynamo/issues/30).
I knew I was overlooking something, thanks.
With Dynamo, the devil is definitely in the details… :wink:
hey guys,
i am trying to use the same nobe with a very simple example but i am getting an empty list, any advice?
cheers
screen 1 screen 2
In his example Andreas plugged the “first” output port, not “in”. Could that be it?
David is correct. Plug the “first” output into the phase and you should be all set.
I am trying to extract co-ordinates of doors/windows from Revit files.
I am new to Dynamo.
Can you please let me know if there is any way to extract the co-ordinates?
I am posting this here as I thought it might be relevant.
Hello Abhijit, I think this has already been discussed in other posts but the forum search function seems to be incapable of locating them. Have you tried with the “FamilyInstance.Location” node?
2015-05-28_11-57-14
It might be better to start a new post next time, so that it’s easier for others to find it.
I tried doing what you suggested.
In my test revit file, I have one room with 2 windows. After I followed the steps you showed, I got an array of 2 (X,Y,Z) co-ordinates.
I did not understand which are these co-ordinates exactly.
I need all 4 co-ordinates of each window/door. Or, at least 2 diagonally opposite co-ordinates of each window to re-create the window.
And if there is a way to extract the co-ordinates, can you please tell me what should I do to write the list of co-ordinates to text file.
I will soon post my problem as a new post as you have suggested.
Thank you.
This solution works great for a few rooms, but with a building with 500+ rooms it takes too long time.
Does there exist another more durable method?
Hi, I’m trying to make this node work for me, but i keep getting empty lists as a result. Can anyone tell me what am I doing wrong?
Hi Dmitrijs,
If your having trouble using clockwork package you can also get what your looking for from Steam nodes “Tools.GetSurroundingElements”.
Thanks for that Kulkul, thats a very useful node.
Just one thing. When I try to use it on walls though, it returns more elements than Id expect (rectangular rooms showing 5 or more walls). I think it counts the adjacent walls as well. Is there a way around it? I tried playing with the tolerance value but it isnt helping much.
walls
Its working fine from my side adjust tolerance see below.
