Hi All,
I am trying to use Room to Element node from Genius Loci, to get all the elements within a room from current documents as well as linked Revit file. Some how the end result of the node is null. Can someone help me on that.
The node “Room ToElement” is looking for a Revit room, right now you are passing in the room name which is a string object type. Below is an example with your get item at index method and a method that would provide a little more parametric value.
