Hello, What should be the input for the tag here?
Thank you.
Anyone?..
It is not considered as a tag
It must be specific (roomtag)
I don’t know if it’s possible via the api (not yet enough level)?
Cordially
christian.stan
Yeah, I understand.
I even can do it with the API but I wonder how to get the Tag from the selected Room Tag!
Thanks by the way. I will make your reply as solution.
It is accessible. Don’t know if there is a node available. But the api can get at it.
import sys
import System
from System import Array
clr.AddReference("RevitAPI")
doc = __revit__.ActiveUIDocument.Document
app = __revit__.Application
uidoc = __revit__.ActiveUIDocument
selection = uidoc.Selection.GetElementIds()
def GetElementSet(elemIds):
myElements = []
for eid in elemIds:
myElements.append(doc.GetElement(eid))
return myElements
e = GetElementSet(selection)
e = e[0]
hasLeader = e.HasLeader
hasElbow = e.HasElbow
leaderEndpt = e.LeaderEnd
leaderElbowpt = e.LeaderElbow
print(str(hasLeader) + "\n" + str(hasElbow) + "\n" + str(leaderEndpt) + "\n" + str(leaderEndpt ))
t = Transaction(doc, "Move Leader")
t.Start()
e.LeaderEnd = XYZ(0,0,0)
t.Commit()
Thanks, Aaron.
Great script!
you can bring the solution to Mr. Aaron I think
Good script suite ![]()
Cordially
christian.stan
