Good evening, I’m writing here because I need your help. I’m working on my thesis and a part of its, it’s the facility management and I would do it for the furniture. How can I tag all furniture with room number (for example in the room 101 I have 5 desks and 5 chairs, so the number should be: 101d1, 101d2, 101d3,… for desks and 101c1, 101c2, 101c3,… for chairs, ecc)?
Thank you so much!
Take a look into this thread:
Hi Ernesto, thanks for your reply. I did your solution and it works but there isn’t the number of the room. There’s just the word “Room”
How can I do to get the number? I’ve replicate your scheme.Hi, @cristina.vagnozzi! Try this solution for your task:
Code for copy pasting:
import clr clr.AddReference("RevitAPI") from Autodesk.Revit.DB import BuiltInParameter clr.AddReference("RevitServices") import RevitServices from RevitServices.Persistence import DocumentManager from RevitServices.Transactions import TransactionManager doc = DocumentManager.Instance.CurrentDBDocument from operator import itemgetter from itertools import groupby rooms = UnwrapElement(IN[0]) furniture = UnwrapElement(IN[1]) TransactionManager.Instance.EnsureInTransaction(doc) furniture_list = [] for i in furniture: loc = i.Location.Point #get location of furniture instance room = doc.GetRoomAtPoint(loc) #get room at that location number = room.Number #get number of room furn_mark = i.get_Parameter(BuiltInParameter.ALL_MODEL_MARK) #get Mark parameter of furniture name = i.Name #get Type name of furniture furn_mark.Set(number+name) #set new value to Mark parameter (number+name type) furniture_list.append([i, room.Number+name]) #creating new list for further manipulation furniture_list.sort(key=itemgetter(1)) #sorting new list by same room names newlist = [[x for x,y in g] for k,g in groupby(furniture_list,key=itemgetter(1))] for k in newlist: #adding to Mark parameter count index of furniture in each room count = 1 for item in k: furn_mark = item.get_Parameter(BuiltInParameter.ALL_MODEL_MARK) furn_mark.Set(furn_mark.AsString()+str(count)) #adding index to Mark parameter count+=1 TransactionManager.Instance.TransactionTaskDone() OUT = furniture_list, newlist
Here is the result:
area room.dyn (10.1 KB)
Thank you Dmytro for the reply. Unfortunately it didn’t work beacuse I’ve a notice on the python script. How is it possible?
Your welcome. You can try to download original dyn file, or just upload a screenshot of the error
I downloaded dyn file but can’t be opened. This’s the screenshot of the error
The error is in italian. In english is "Notice: IronPythonEvaluator. EvaluateIronPythonScript operation failed.
File “”, line 20, in
AttributeError: ‘NoneType’ object has no attribute ‘Number’ "
Oh, my mistake… its because in your model there are furnitures outside rooms. Replace code with this one. This script works only with furnitures that are located in rooms
import clr clr.AddReference("RevitAPI") from Autodesk.Revit.DB import BuiltInParameter clr.AddReference("RevitServices") import RevitServices from RevitServices.Persistence import DocumentManager from RevitServices.Transactions import TransactionManager doc = DocumentManager.Instance.CurrentDBDocument from operator import itemgetter from itertools import groupby rooms = UnwrapElement(IN[0]) furniture = UnwrapElement(IN[1]) TransactionManager.Instance.EnsureInTransaction(doc) furniture_list = [] for i in furniture: try: loc = i.Location.Point #get location of furniture instance room = doc.GetRoomAtPoint(loc) #get room at that location number = room.Number #get number of room furn_mark = i.get_Parameter(BuiltInParameter.ALL_MODEL_MARK) #get Mark parameter of furniture name = i.Name #get Type name of furniture furn_mark.Set(number+name) #set new value to Mark parameter (number+name type) furniture_list.append([i, room.Number+name]) #creating new list for further manipulation except: 0 furniture_list.sort(key=itemgetter(1)) #sorting new list by same room names newlist = [[x for x,y in g] for k,g in groupby(furniture_list,key=itemgetter(1))] for k in newlist: #adding to Mark parameter count index of furniture in each room count = 1 for item in k: furn_mark = item.get_Parameter(BuiltInParameter.ALL_MODEL_MARK) furn_mark.Set(furn_mark.AsString()+str(count)) #adding index to Mark parameter count+=1 TransactionManager.Instance.TransactionTaskDone() OUT = furniture_list, newlist
Just for clarity. In my case index ‘C’ and ‘B’ is a family type name
I haven’t there aren’t furniture outside rooms. All furniture are inside! Unfortunately new script it doesn’t work because revit isn’t responding when I run the configuration with this new script.
I would go back to this version of the graph: Furniture name by room name - #3 by Ernesto_Pellegrino
Replace the Elements.Name code block with an Element.GetParameterValueByName node where the parameter name is the room number or room name (not sure what you are appending).
At least you can try to do the same thing on blank project, with not many elements. If it works then maybe there are too many elements in your main model and its a question of time for script to solve the task.
If not, then im not sure what is wrong and my apologies - i hope someone will give you an assist
Thank you Jacob. I did as you suggested me. There are no errors but I can’t see the number of room. I would have a configuration as “221D_01”, where 221 is the number of the room. The scheme I’ve set is this:
.The result I get is this: .
As you can see in the tag misses the number of the room. Where would be the mistake?
Also I would that the number after the “_” restart for each room (for exampe 221D_01, 221D_02,…; 222D_01, 222D_02,… ).
Is it possible?
Thank you so much for your help!
Enable all node previews, and post an exported image of the Dynamo graph (use the camera export in the top right after zooming in so the previews are legible). It may be that the parameter name is spelled incorrectly.
I think you need to replace the code block Number with the string “Number”
Try copy/paste “Number”; inside your code block ( including quotation marks “” and semicolon ; )
Unfortunately nothing is changing. There could be some other mistake? I’ve tried with both solution: replacing the code block Number with the string "number, and copy/paste “Number”; in code block, but the result is the same before.
The quotes identify data as a string in a code block. If you use a string node there is no need for them, as Dynamo already knows what the data type is.
So remove the quotes and the ; from the string node and it should update. Also, turn on all the node previews if this doesn’t update.
Finally I get it!! Really thank you so much for your help!!
