Help.
I’ve been struggling for a few days now. I tried the method I used for Revit 2021/Dyn2.6.1
but I’m not managing to get it to work for 2020/Dyn 2.3.0. At Element.Geometry I’m getting an error - One or more geometries have failed to convert due tp thos errpr: Curve join produced more than one WIRE in PolyCurve.
Pretty much the same result. At List.getItemAtIndex I’m getting - “Operation failed. Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index”
The problem comes with these “-1” that I’m getting at List.IndexOf.
I’ve considered RoomAtPoint from archilab, as also advised by newshunhk but I’m not sure which version of archilab has it and if it’s supported by revit 2020/dynamo 2.3.0. Which version of achilab do you have?
