Room Geometry Showing After Closing Dynamo
Hi guys,
After RUN a DYN FILE, the ROOM was drawed in my design.
It’s just a image, there is no how to select and hide, but, it’s very bad to back to work into the project.
I saw, that came into the GENERIC MODEL category.
Is anybody know about this?
My DYN FILE is using ROOM to a lot thinks.
AMBIENTES == ROOM
BEFORE RUN:
AFTER RUN:
JUST THE ROOM DRAWED:
That looks like it is the preview of the Element.Geometry node and sounds as if it is the preview since you cannot select it. How did you determine it came in as a Generic Model? :thinking: It should turn off in your Revit views by either disabling “Revit Background Preview” or by turning off the Preview on the Element.Geometry node. If you already exited Dynamo and the geometry is still there, you can close and reopen your Revit project and that geometry will no longer show.
Yes, i can’t select.
I didn’t determined to became a Generic Model.
Where can i disable “Revit Background Preview”?
Or, how to turn off the Preview on the Element.Geometry?
You are right, when i close and reopen my project, back to the normal, without room drawed.
Here shows where both settings are (menu on Element.Geometry node comes from right-click):
