After running some geometry selections in dynamo, dynamo colors things this ugly yellow orange color. Then even after exiting dynamo the selection color still exists. How do I get rid of it? thanks,
I am having the same problem with Revit 2016 and Dynamo 1.2.1.3083.
Every time I run I script and then close Dynamo the preview does not disappear in Revit.
I need to restart Revit. It is actually an annoying bug indeed.
Is this common to many users?
Any news on a fix for this? Closing and opening the Revit file is quite annoying.
Thanks a bunch JP
I run a large scale script for a modulation covering object it seems that blue line are glitch. Still trying to look for a solution.
anyways, got the answer from this tread http://dynamobim.org/forums/topic/geometry-from-dynamo-to-revit/.
it’s a bad thing if you guys started to use it with these category is checked. Be careful.
Page not found
use the Wayback machine!
whttps://web.archive.org/web/20160317215058/http://dynamobim.org:80/forums/topic/geometry-from-dynamo-to-revit/
