Room and Tag Location - Definition not Loaded
Continuing the discussion from Create Elevation by Rooms:
Your missing custom node anytime you need to know what package a node is from. try downloading package WhatTheNode.
Essentially you type in the node name as a search string and get results of the likely package.
Rhythm.WhatTheNode returns a null on my end. A simple Google search leads to better results. See:
Yeah. That node is a hit or miss as it relies on dynamonodes.com to be up to date.
@john_pierson - Out of curosity, how does it deal with name clashes?
it takes the first one :slight_smile:
To find out packages that custom nodes are on, i just right click them and select “Custom node properties” this has the metadata with the package name.
If you never found the node, it was from Modelical packake
@Archinecture, Yes, @Alisder_Brown is right. This node belongs to our package (MODELICAL). You can check it by right-clicking on the node, on the help tab as shown in the picture. I will try to have our package included on dynamonodes.com so that it also appears with the Rhythm.WhatTheNode.
I hope it’ll come in handy!
