Rib vault in Dynamo
I am currently creating a ribbed vault. So far I have managed to create all the arches and diagonal ribs. The next step would be to create a surface to fill the gap formed by both edges and ribs(according to the image it is a panel). My idea is to create a mesh that I can then use to place adaptive panels. Attached image.
Thanks!!!
Welcome to the Forum
Take a look here, it might be what you are looking for.
Thank u! But I am looking for a solution with Dynamo.
Can you show us what you have tried?
Here is an example
What does the error say?
It says that the curve is not closed
Fix that first
In the end you need to have a list of 4 corner points for each panel in the correct order in a sublist (nested list).
And your Family needs to of the (Conceptual) Mass Category, i think.
Maybe others can help too
