Rhythm Crashes Dynamo
Dont know if anyone else had this issue
C:\Users{USERNAMEHERE}\AppData\Roaming\Dynamo\Dynamo Revit\2.17\packages
Got these errors and my Dynamo crashed the whole time.
So I removed the Rhythm folder
My Dynamo works now, don’t know if it will affect the functionality of Dynamo?
Hi and welcome!
Are you using Revit addins?
Sometimes. I only use DataShapes add-in + just so happened to have to use Rhythm (which I removed)
I think I might’ve just solved the issue; by removing the folder from the add-ins and then just installing it again via Dynamo Search for packages.
The add-ins question was for Revit add-ins. Likely the issue was an incompatible Rhythm package (ie: one built for Revit 2019) for the newer Revit build, which would have been resolved by getting a new build from the package manager.
