We are having problems when we try to import a solid from Rhino in Revit using Dynamo /Rhynamo.
We have done the dynamo node attached:
https://drive.google.com/open?id=15_AZ0cZNIQThu6yi01EbV9Vj5lYtz453
and the solid arrives to Revit but we can do nothing with it (we can’t change parameters, we can’t place it in a specific point or similar things).
The model we are using for the test is the attached in this link (.3dm). https://drive.google.com/open?id=16JSUw032OktkVE3s3evctf8CdoffYcox
Do you have any idea whats happening?
Thannks,!
Can you select the element?
When the model arrives to Revit, I can select it by doing one clic and it shows some properties, as you can see in te image attached in this link https://drive.google.com/open?id=1NTQQqcRlBxO9vP1Ta5uv5q7t1BYN5RqI.
But I don’t know how to change or add parameters or change materials.
I would like to create a family having this model as base. And changing or making parameters get a family, but if I import it as family and i try to edit it I need to redraw all the model, so it is not very useful.
Try editing the family as you would any other Revit family to add parameters.
