Rhino to Revit Via Dynamo v.1.1.0 / Rhynamo 2016.5.3
Hello!
I am working on translating this .3DS geometry to Revit and I would like to create walls from the surfaces of the Rhino file.
I did not create the original Rhino geometry and this was generated in a very free form manner so to rationalize this and turn this into Revit content through an adaptive component or otherwise will potentially take a long time - I’m hoping there may be a way to skip a step or twenty?
I am working in Dynamo 1.1.0 and with Revit 2017 for this study.
I have the following packages installed:
archi-lab_2016.5.27
Bakery_2016.9.7
BumbleBee_2017.11.2
BVN_1.1.0
Clockwork_0.90.7
ListContains_0.1.0
LunchBox_2016.7.2
Rhynamo_2016.5.3
Rhythm_2016.9.7
SpringNodes_100.0.1
SteamNodes_1.0.0
I looked at these videos by Zach Kron:
I can see the geometry in Dynamo, but I can’t get Revit to make walls based on this. I only noticed three nodes that could potentially do this and one works but only barely. It makes a bunch of straight walls.
Let me know if you have any suggestions. I tried FormIt but the geometry comes in faceted or as an import element.
Tom Vollaro suggested Rhynamo. This is the first time I am touching this today.
Thanks!
Rhino-Test-Form.3dm (1.1 MB)
Mass_Rhino-Dynamo-Rhynamo-Revit-Exchange_Emily_2017_1.1.0.dyn (53.8 KB)
Hi @Emily_Dunne
You need to convert those polycurves to curves using “Polycuve.Curve”.
K - I’ll try that. Thanks! :smiley:
I get an error about asked to convert non-convertible types and also an operation failed warning.
Maybe I need to filter the types of curves in the list by boolean mask?
Also, I think the large central curve comes in as an extrusion but I have not found a wall by extrusion node. :confused:
@Emily_Dunne Here is one of the possible way to do…
Here is the DYN file Mass_Rhino-Dynamo-Rhynamo-Revit-Exchange 1.2 (For Emily).dyn (14.6 KB)
I gave up and just redid the geometry in Revit using adaptive components. This is a cool workflow though. I am checking out your DYN file right now.
