Hi All, I want to export my Rhino file to Revit with Rhynamo and Dynamo, but I have a problem to read the geometry in rhynamo.
I have created a exstrution geometry into Rhino and I want to use " Rhino Extrusion to DS" but the command sends me this error:
Any advice?
Hi Sonia,
Have you seen this post? Dynamo not reading Rhino geometry It seems it works with Rhino 5 and Dynamo 1.3 only. You may try with MantisShrimps.
I’ll suggest you also have a look Speckle (https://speckle.works/log/speckle-guide/ Here’s a list of object implemented https://github.com/speckleworks/SpeckleDynamo/issues/10) or RhinoInside Revit (https://github.com/mcneel/rhino.inside/tree/master/Autodesk/Revit) as they are the most up to date solutions.
Ciao
Giovanni
