Hello Community
I am currently struggling with a bit of a problem and need some help to solve it.
The outcome I am looking for is to convert rhino data into structural members and schedule them.
My problem is that I do not know how.
If this is not achievable I would like to pull data from rhino. The data that I am after would be the diameter of the circle and then the length of each extrusion.
Any help or direction is appreciated and thank you in advance.
I have attached an image of the geometry that I am trying to schedule.
Hi @Bobby_Harris1,
It would be a lot easier to help if you share the rhino file as well as showing what you’ve tried so far
A workflow could be done using nodes from the rhynamo package, but it could also be set up as a live stream via grasshopper and speckle. Let us know what you are after.
Hi Martin,
Thank you for the reply.
I have simplified the geometry and attached the files.
serpante.3dm (3.9 MB)
Rhynamo_Workflow01_ExampleImport.dyn (17.7 KB)
I really have no idea where to start.
Again any help is appreciated.
So I have backed up to the start.
I have simplified the geometry that I am trying to import to just the base circles.
What I need help understanding now is how do I convert the rhino polycurves into revit curves or circles to which I can find the center point of?
serpante-circle.3dm (144.6 KB)
Rhynamo_Workflow01.dyn (8.5 KB)
So I am pretty happy with myself… I am moving in the right direction.
Rhynamo_Workflow02.dyn (200.9 KB)
serpante-circle.3dm (168.8 KB)
Hi @Bobby_Harris1,
Great stuff
. I actually had a go with your 3dm last, but had some troubles getting geometry into dynamo. My comp died several times while trying to get the whole lot, but in the end I successfully got a single surface out. Don’t know if it’s because of the extends of the geometry it’s hard to convert, or because the geometry is not a proper brep - it’s definatly not too complex.
But I decided to install rhino to check out your file and see if I could get just the center point, radius and length of the pillars, and then send this data via speckle, but I didn’t get that far last night. I’ll try again when I get time
@Bobby_Harris1,
So I just tried to solve this via Speckle, since… well… it was fun
And then, as I mentioned earlier, had some trouble getting the geometry through Rhynamo.
Spoiler alert: This will display extremely bad use of GH since im a total noob
So here goes:
I managed to extract the center line midt point and an edge curve, which i send through to Dynamo using Speckle:
I recieve the geometry in Dynamo, and extract the curve of the column as well as the radius and the height. This information i pass through to the adaptive family column I’ve used:
In Revit where you can schedule the elements (I would have showed this if I’d used shared params in the family, but I’m sure you’re aware of how to do this
Edit: I edited the 3dm file a tiny bit, since it had some columns inside other columns:
serpante_SpeckleTest.3dm (3.8 MB)
Edit 2: Link to how to set up a stream using Speckle:
I am working on a new approach.
My new idea is to create polylines through points and bring that data into dynamo then convert that data into columns but I am not having any success.
Could someone please help.
Thank you in advance.
serpante-columns.3dm (1.6 MB)
Rhynamo_Workflow03.dyn (7.0 KB)
