Hello all
I was hoping for some help with a node problem. I am trying to create a simple Revit sheet creation script reading from an excel file.
The script works to the point that it can read an excel file as requested and create two lists, one for sheet names and the other for sheet numbers.
The final node is causing problems. I am using a Placeholder.Create Sheet node with 2 inputs, sheet name and sheet number. The sheet family type is missing.
I see from other examples that the Archi lab node Create Placeholder Sheet should be used but I cannot find this, even when I download the latest Archi-lab package.
By the way, I downloaded the latest Dynamo version yesterday so that should cause problems, I think
Any thoughts?
