Revit (Metric) and Dynamo (Imperial)? - R2020 D2.3
How do I change Dynamo to Metric?
All my Revit Units are metric millimeters, but Dynamo nodes use imperial feet?
Manual input in revit:
E.g. Element.SetParameterValyue
You will have to convert them in your graph. There are nodes to help, or just do the math manually.
I have always been able to input millimeters… Besides the API, it should not be necessary to convert to feet in Dynamo.
It’s not Dynamo, Revit uses inches under the hood.
I know, but it has never been necessary to convert to imperial units. Dynamo normally follows the units used in the Revit project…
Problem solved!
The DynaMEP package also have a node called Element.SetParameterValueByName… Same name, inputs, and output. This node does NOT follow the Revit units like other packages, it uses imperial units!!! :frowning:
