Thank you @Durmus_Cesur!
The screenshots were not created in Revit.
But here is an example file, with the cross-section crvs. facade_types.dwg (211.1 KB)
@jacob.small, what would be the difference between these two approaches? The one with creating a new family, and adaptive components? Only that easier placement?
If you have a simple, flat glass facade, a third option could be to use Curtain Walls and replace the panels with windows.
You need to create a window family starting from a Curtain Wall - Panel or a Window - Curtain Wall family template. (or edit an existing one, there is one in the 2019 US Library).
When you have to schedule them, you might Dynamo to group the family instance according to dimension.
Thank you very much @lucamanzoni !!
What would happen if corners of the facade are suppose to be filleted_
Can the solution that you showed be used in that case?
Here is top view of the facade:
Easier point placement with family instances. Greater flexibility with adaptive components (let’s say you need the stack 3” shorter - that’s new families or adjust your points). Easier to embed in a wall with families. Easier to get a consistent, “just the glass please” look with adaptive components.
Since you’re filleting the corners, either the CW tool or the adaptive component method will create a filleted look.
It is also worth mentioning the downside of adaptive components here.
Even though they are massively cool and flexible, they are also, if placed in large numbers, gonna make your model gain some serious weight, which will effect performance.
If this is the case, then it might be worth considering using ordinary generic models instead, when the design is final.
