Hi Matt,
Yes, agreed, there’s not much out there. Which means you’ll likely need to do some coding to get exactly what you want.
The only node I’m aware of is Springs.AdaptiveFamily.ByFacetedGeometry. Here’s a thread on the use of it, where @Dimitar_Venkov gives a link to samples on his Github:
It doesn’t sound exactly what you’re after, but if you click into it you can see the Python that’s been used and perhaps create your own version. Dimitar is a Guru, so it won’t be easy.
Hopefully that’s useful.
Mark
@Dimitar_Venkov loving the class ‘PtsErrorMuncher’ ![]()
