Hi Can anyone help i have a dynamo script for scheduling the inner radius of fabrication bends all works ok in revit 2019 but I cannot get it to work in revit 2020 does anybody have any idea please
What does the warning bubble say?
which custom node are you using?
what is the error message?
Hi sorry for the late reply I have been away
The Fabrication Part Dimension says: Error: Custom node not loaded
The Aw Number.To String says: Warning: Method ‘__func_7138be89af7b4232b938e63a5fe78240()’ not found
The Element.SetParmeterByNAme Node says: methods or properties: ‘Revit.Elements.InternalUtilities.ElementUtils.SetParameterValue(Autodesk.Revit.DB.Parameter, Revit.Elements.Element)’ and ‘Revit.Elements.InternalUtilities.ElementUtils.SetParameterValue(Autodesk.Revit.DB.Parameter, string)’
Image Below
been playing around and now got the Fabrication Part Dimension Node to say: Warning: This custom node contains an invalid input. Please fix the input before saving the custom node.
Sometimes it seems to work if I do a force run?
