After loading the Genius Loci Dynamo Package, I am getting the following Dynamo Exceptions.LibraryLoadFailedExpcetion: Failed to Load Library: Dynamo.Exceptions.LibraryLoadFailedException: Failed to load library: C:\Users%USERNAME%\AppData\Roaming\Dynamo\Dynamo Revit\2.3\packages\Genius Loci\bin\itextsharp.dll
Build error for library: C:\Users%USERNAME%\AppData\Roaming\Dynamo\Dynamo Revit\2.3\packages\Genius Loci\bin\itextsharp.dll
Can’t import System.Collections.Generic.Dictionary2+ValueCollection[[System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.Int32[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]], ValueCollection is already imported as System.Collections.Generic.Dictionary2+KeyCollection[[System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]], namespace support needed.
Any ideas on how to get this corrected? Doesn’t appear to be affecting the function of the package at this time, but would like to solve the mystery if possible.
