Problem when deploying a package with versions later than 2020
Hello.
I`m developing a custom package for the company i work for. It works perfectly for revit 2020.
But it doesn`t matter what i do, the package simply can not be loaded into dynamo versions for revit 2021, 2022 and 2023.
I`m creating a folder at %appdata%\Dynamo\Dynamo Revit%Dynamo Version%
Dynamo versions are:
2.6 for Revit 2021
2.12 for Revit 2022
2.13 for Revit 2023
when i manually try to load my assembly from %appdata%\Dynamo\Dynamo Revit%Dynamo Version%\packages\MyPackage\MyPackage.dll dynamo says it couldn`t load the assembly.
On the notifications tab of dynamo i get the following message.Dynamo.Exceptions.LibraryLoadFailedException: Failed to load the library: MyPackage.dll
When i press show details it states the following:
Error generating the library: Mypackage.Dll
Failed to import Mypackage.dll
Exception of type ‘ProtoCore.BuildHaltException’ has been fired.
I`m going insane with this.
Any help?
Thank you all in advance
@Ramoon_Bandeira ,
For package management and deleting. Revit has to be closed!
KR
Andreas
I actually build the solution, which compiles and copy all the dependencies to the correct folder, before opening revit.
So i guess that unfortunately this is not the problem
@Michael_Kirschner2 any thoughts on this one?
debug Dynamo to see where the build halt exception is thrown - this will probably make it easier to reason about what is going wrong when importing.
We have some tasks in the backlog to make zt import failures contain better logging.
How to debug a solution that only contains node models?
The exception is not triggered in visual studio. It never reaches the point where we start debugging the nodes from the solution
