Generative Design Revit Dynamo Load Error
Has anyone else received this error in Revit 2021 Launching Dynamo to work with the New Generative Design Feature? Dynamo.Exceptions.LibraryLoadFailedException: Failed to load Library: C:ProgramData\Autodesk\RVT 2021\Dynamo\2.5\packages\GeneratvieDesignRevit
Working on a VM
image|452x500
This is a known bug related to a certificate. Dev team is actively looking into a fix and will hopefully have something soon.
FYI @Lilli_Smith @Zach_Kron
I did get it to launch in dynamo as the VM is a test deployment system and we put the package in a different folder than. It still throws the certificate errors but runs
as I replay from my work account not my personal lol
Fix is posted now
https://manage.autodesk.com/cep/#products-services/updates
Thanks!
Hello together,
the fixed certificate expired so the issue occurs again:
grafik
Could you help me and update it again?
best regards,
Mathias
Hi @mathias.worm,
Updating your Revit installation to Revit 2021.1 should fix this error. That will update the version of Dynamo for Revit to 2.6, which includes the updated certificates you need.
Hi @nate.peters,
the update fixed the issue. Thank you!
