Hey all,
As the title states, my Revit crashes when i try to open a script, not sure whats happening as its happening in all my versions on revit and Dynamo…
Tagging @jacob.small since I think you usually find the issue very quickly…
I attached the autodesk journal for the error log.
journal.0120.txt (153.0 KB)
Is it one particular script? I can see from the logs you were running Dynamo at one point.
Likely it’s a conflict between a package and an addin, or with multiple versions of a package trying to load into the workspace at the same time (ie: Archilab X.Y.22 and Archilab X.Y.23). Confirm you don’t have doubled packages as a first step; then disable all Revit add-ins as a second.
Hi Jacob,
It happened with every script i have. A simple reboot seems to have done the trick…
