Hi Everyone,
I have to work on an old project using Revit MEP 2012. Is there a limit to what version of Dynamo Build I should install on this version of Revit?
Thanks,
Hi Everyone,
Thanks,
I’m not sure, but under Autodesk’s “3 prior versions” licensing, does your Revit 2012 still work ?
Although upgrading across such a wide gap in versions may be problematic, I would try this route first
Andrew
Try with one of the 0.6 versions. If I remember correctly, I managed to run 0.63 on 2012. Tho I think you had to install it in 2013/2014 first and then copy the addin to make it work…
Thanks for the replies. I’ll try out the 0.6/0.63 versions as mentionned.
To many crashes happen for me with 0.6.3. and I have no programming experience to modify python scripts to react well. At least I tried something. Thanks for the suggestion. https://github.com/DynamoDS/DynamoRevit/issues/994
0.7.1 doesn’t work either… I tried!
Did you tried Dimitar’s solution?
Do you have other Revit version or just 2012 is installed?
