HI,
I wanted to know if there is a way in Dynamo to find the coordinates of the corners of a column imported from Revit.
I have to export all the values in excel
thanks
Hi David,
Are you looking for Top Coordinates or bottom of the column?
thanks Kulkul,
bottom of the column, the supporting base, I need this information for setting on site
Below is an example workflow of 4 columns.
Sorry KulKul,
I can not see the image, I do not know why, can yuo send me an e mail or a private message on the forum??
turinadavide@gmail.com
thanks
ok, sorry, now i see all image… one minute
No Problem. Here is the dyn file Columns Botttom Coordinates.dyn (7.0 KB)
Try this,
After “AllElementsOfCategory” use these nodes -> “Element.Geometry” -> “Geoemetry.Explode” -> Surface.FilterByOrientation. See if that helps.
Hi David
In this case. You need to start new topic your question is off topic. Thanks ![]()
Right! sorry
Thanks!!
You could try this too…
ColumnsBotttomVertices.dyn (7.2 KB)
Introduce a Flatten node between Element.Geometry and Topology.Vertices
nothing, gives me the usual error
Seems like not all geometry in Element.Geometry list are Solids.
Try filtering out no solids and see it it works.
You could use RemoveIfNot node to do so
