Center line for the column, having an error
I created this Dynamo to provide the center line for column, but is am missing something here.
I am messed up with the surface may be. any one can fine the solution, it would be very useful
setting out.rvt (2.1 MB)
SETTINGOUT.dyn (603.3 KB)
Thankyou
or to convert the centroid of the column to curves, I don’t know how it will work
Hi @vikas.kpoojary try element location curve from genius loci, if you are in older version
See this line is moving vertically but i need it too move horizantally
do you mean something here ? rough exemple
when i select the element and extract the faces/curve, a random face will be selected all where shuffled, why, how, i have no idea, but i need that blue line face or line coordinate to draw Detail line like
this
check with the dynamo i attached may i know where i went wrong, it would be very thankful and sorry for bothering you.
@vikas.kpoojary
Here’s rough way to get the top of Col.
231204_CLofCol.dyn (47.3 KB)
Cheers KS
arhh ok, then i would try as Kai suggest or something here maybe…
thanks its working
Thankyou its also working fine
