Is it possible to retrieve Visibility Graphic Overrides for view(s)? Not graphical overrides of elements in the view but the actual VG overrides. See image below. Through researching on this forum I have been able to locate a block of code provided by @Dimitar_Venkov. It will grab the required information for the category but not the subcategories. I have attempted to modify the code to attempt to also retrieve the information for the subcategories but have been unsuccessful. Any help anyone is willing to provide is always greatly appreciated. Thank you.
@Dimitar_Venkov code:
dataEnteringNode = IN
clr.AddReference('RevitAPI')
cat = UnwrapElement(IN[0])
v1 = UnwrapElement(IN[1])
OUT = cat.GetGraphicsStyle(GraphicsStyleType.Projection), v1.GetCategoryOverrides(cat.Id).ProjectionLinePatternId, v1.GetCategoryOverrides(cat.Id).CutLinePatternId
