Hi All,
I’ve adapted the below python script from Element color override in viewS and I would like to feed in an OverrideGraphicSettings object from the OOTB node OverrideGraphicSettings.ByProperties
My problem is that the object output by this node is of Revit.Filter.OverrideGraphicSettings type and method used in my python script, SetElementOverrides, calls for an Autodesk.Revit.DB.OverrideGraphicSettings object.
Is it possible to use the OOTB node by tweaking my script to cast the first object as the second type?
This is the set up for this process:
The error that I return from running the script as above is:
Thanks for reading
Hi @stefan.c,
Have you tried to Unwrap() your OGS input?
Hi @MartinSpence,
Thanks for your response.
Making this change gives me the same error message:
Ah yes, I just noticed the Revit.Filter.OverridesGraphicsSettings output.
I’m not familier with a way to change this to the OverridesGraphicsSettings. You may need to create this within the python script.
As far as I know, UnwrapElement will only work for actual Elements, however OverrideGraphicSettings is not a subclass of Element. There is a similar method called ToRevitType(), but this is only used for geometry conversion. It looks like your only option is to construct the OverrideGraphicSettings manually. Note that the available methods have changed for Revit 2019 and 2020 (with the addition of foreground and background).
I struggled with this issue a while back, and instead resorted to creating the OverrideGraphicSettings within the Python code, as @cgartland suggests
# Enable Python support and load DesignScript library
# Import Element wrapper extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
items = UnwrapElement(IN[0])
view = UnwrapElement(IN[1])
fillColour = UnwrapElement(IN[2])
lineColour = UnwrapElement(IN[3])
pattern = UnwrapElement(IN[4])
ogs = OverrideGraphicSettings()
ogs.SetProjectionFillColor(Color(fillColour.Red, fillColour.Green, fillColour.Blue))
ogs.SetProjectionLineColor(Color(lineColour.Red, lineColour.Green, lineColour.Blue))
ogs.SetProjectionFillPatternId(pattern.Id)
for i in items:
view.SetElementOverrides(i.Id, ogs)
I agree with @Thomas_Corrie solution though i would suggest you add a revit version checker to switch between what thomas has put and the new “BackGround” and “Foreground” version of the methods which you can find here(with a example below).
https://www.revitapidocs.com/2019/bd467fbb-a9da-7cf1-1ef5-f0f3568db0ac.htm
Note:Obsolete means they should be avoid from that version of revit on wards as they will be deleted out at some point.
Example:
Thanks all for your responses.
I created a separate python node to output an OGS of the correct type as suggested by @cgartland and based on @Thomas_Corrie’s suggestion:
I’m in 2017 for legacy project reasons but will roll in @Brendan_Cassidy’s suggestion when I move to 2019
Much appreciated
@Brendan_Cassidy thanks very helpful I would like to use this if clause in other definitions as well but
how do you call this version? Self. Do you have a class for it? I beg your pardon if this is a too dumb question!
Without seeing the python code in question cannot say for definitely that the below will work 100% perfectly if you copy it into yours.
You should be able to use the following to get the revit version, then switch “self.revversion” in my original code with “appVersion”
app = uiapp.Application
# app Version to Number
appVersion = int(app.VersionNumber)
