[Request for Feedback] TuneUp: Per node execution times
Maybe you are right, I should probably experiment more and try to go deeper :slight_smile:
Another thing I thought about - it would be amazing if the execution time could be taken as an output, I have been thinking for a while it would be nice to have that information for each run, even when graphs are used through Dynamo Player.
Anyway, the tool is amazing and I can’t wait to see how it will be developed in future!
if you can find some simple to reproduce cases with your files where incorrect times are reported etc - please file an issue to the tuneup repo - or a PR!
Just wana say this is fantastic :star_struck:
I installed the latest version from package manager 1.0.7 it in Dynamo of Revit 2022 and Revit 2021 which have by default versions of Dynamo 2.5+ but i do not see the functions anywhere in the interface or options, how to enable the package tune up?
Restart your CPU to make sure TuneUp can load and nothing is ‘using it’ and then look into the ‘View’ menu in Dynamo.
error installing, does it work only in newer dynamo or revit versions than 2021?
Works fine in 2021 - your not facing a package error but an installation one. Make sure you don’t have any conflicts, the previous version isn’t installed and in use, and that your package directory is the default app data one.
I see a directory created C:\ProgramData\Autodesk\RVT 2022\Dynamo\2.10\packages\TuneUp, although nothing appears like if not installed, do I need to manually install it from a directory?
You don’t have write access to that directory. Installation location should be in your appdata directory (one user only) not program data (entire system).
Does tuneup work in R25?
Not at this time. :frowning:
Its being updated right now! Then improved after the base works :blush:
Any further information @Aaron_Tang ?
@ashish.ganta Is in the process of re-publishing it, will let you guys know once it’s out there
Hi @solamour
How does tuneup 1.0.9 work in Civil3D 2025 / Revit 2025?
In Revit 25 it works for me when I change the language to english. In german it is not working or I don’t see it in the extensions tab.
In Civil3D it doesn’t work at all.
I saw that 1.0.10 is being worked on? Will it be published soon?
Hello @genossealex,
As TuneUp is a package right now, we’re not localizing the content (But plans to do so for when it’s integrated out-of-the-box) and so will only work in English right now. It should still show up in the Extensions tab, just be in English, so that sounds like a bug :bug: we’ll look into that!
It shouldn’t also be tethered to Revit only, so we’ll test in Civil 3D and get back to you.
TuneUp 1.0.7 worked in Revit 2023 and Civil3D 2023 and also in german.
