Replace textnote
I am using revit 2019 and dynamo 2.0.2
The “replace” textnote ain’t working anymore because parameter “Type” is not available anymore
So i tried it to do another way to change the parameter “Type Name” but this is a read only parameter.
Is there a way to replace textnotes, or change textnotes in specific views?.
thnks.
i think this wil help you!
did the solution in your first picture work in previous versions?
Hi there
thans for the link it helps to solve my problem.
I believe yes. A while ago i found this Find and Replace Text Note Types - #12 by awilliams
And here it works with Textnote and TextNoteTypes (see post #12 from @awilliams)
Now the methode only works with TextNotes → so feed TextNodes into the Elements in the Elements.SetParameterByName node.
