Replace by condition not working
This command is exactly copied from the website but does not seem to work. Anyone has any idea about how I could replace numbers at certain index?
Thank you!
This should provide some clarificaton.
Youc an also check out the sample if you right click on the ReplaceByCondition node and select ‘help’. If you’re in a recent build (2.16+ if memory serves) you can insert the help graph directly into your graph as well. :slight_smile:
