Error with ReplaceByCondition in Dynamo
I’m having some problems with the script in the image. I’m trying to replace some elements of a string that are equal to “.” with a different string, but the command ReplaceByCondition doesn’t work and I don’t know why.
Thank you.
FB
@f.brusiani .
try codeblock…
x == "." ? " " : x #codeblock
KR
Andreas
The ReplaceByCondition node uses a function for the condition in question. That’s a specific object type, where the “function” node (== in your ase) is missing an input that then pulls from the item input. If you already have the boolean results you can just use an If node.
